Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the two screws on either side of the green circuit-board as seen in the photos.  Once the screws are removed, gently lift the board so you can remove the disc drive.  BE CAREFUL! The board is still attached to the base of the DVD player.  You just need to lift it enough to pull the disc drive out. Remove the two screws on either side of the green circuit-board as seen in the photos.  Once the screws are removed, gently lift the board so you can remove the disc drive.  BE CAREFUL! The board is still attached to the base of the DVD player.  You just need to lift it enough to pull the disc drive out. Remove the two screws on either side of the green circuit-board as seen in the photos.  Once the screws are removed, gently lift the board so you can remove the disc drive.  BE CAREFUL! The board is still attached to the base of the DVD player.  You just need to lift it enough to pull the disc drive out.
  • Remove the two screws on either side of the green circuit-board as seen in the photos. Once the screws are removed, gently lift the board so you can remove the disc drive. BE CAREFUL! The board is still attached to the base of the DVD player. You just need to lift it enough to pull the disc drive out.
Insérez ici votre traduction
