Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly. Place a suction cup near the bottom edge of the display. Pull on the suction cup with strong steady force.
  • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
  • Place a suction cup near the bottom edge of the display.
  • Pull on the suction cup with strong steady force.
  • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
  • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
  • Do not use metal tools, as they will most likely crack the screen.
Insérez ici votre traduction
