Aller au contenu principal
Anglais
Français
Traduction de l’étape 8
Étape 8
Disconnect the power connector cable by using the point of the plastic spudger. continue to slide the plastic part  until it is completely removed or you are able to grab the plastic with your fingers.
  • Disconnect the power connector cable by using the point of the plastic spudger. continue to slide the plastic part until it is completely removed or you are able to grab the plastic with your fingers.
  • It is not advised to pull the cable bundle to remove this. By doing that you can damage the small wires that are connected.
Insérez ici votre traduction
