Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Remove the 3 Phillips #0 screws from the fan bracket. Lift the fan up and place it back down above the heatsink. Do not fully remove the motherboard. As there is hidden cable on the underside that could be damaged.
  • Remove the 3 Phillips #0 screws from the fan bracket.
  • Lift the fan up and place it back down above the heatsink.
  • Do not fully remove the motherboard. As there is hidden cable on the underside that could be damaged.
  • The heatsink has a strip of adhesive on the underside securing it to the plastic body.
  • The motherboard can be lifted from the side and and then to the right to free the I/O port from the enclosure. Some force may be required to release the heatsink.
Insérez ici votre traduction
