Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Pull on the hood release lever just inside the passenger door to pop the hood. Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood. Insert the hood prop rod into the hole in the hood marked with an arrow.
  • Pull on the hood release lever just inside the passenger door to pop the hood.
  • Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
  • Insert the hood prop rod into the hole in the hood marked with an arrow.
Insérez ici votre traduction
