Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 2
Étape 2
Locate the plastic push pins along the bottom of the bumper. Use a small thin prying device, such as  a flathead screwdriver, to pop the heads of the push pin up. Then remove the entire push pin assembly from their holes. Use a small thin prying device, such as  a flathead screwdriver, to pop the heads of the push pin up. Then remove the entire push pin assembly from their holes.
  • Locate the plastic push pins along the bottom of the bumper.
  • Use a small thin prying device, such as a flathead screwdriver, to pop the heads of the push pin up. Then remove the entire push pin assembly from their holes.
Insérez ici votre traduction
