Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Using a Phillips #0 screwdriver,  remove the four 10mm screws located at the back of the device. Using a Phillips #0 screwdriver,  remove the four 10mm screws located at the back of the device. Using a Phillips #0 screwdriver,  remove the four 10mm screws located at the back of the device.
  • Using a Phillips #0 screwdriver, remove the four 10mm screws located at the back of the device.
À l'aide d'un tournevis cruciforme n ° 0, retirez les quatre vis de 10 mm situées à l'arrière de l'appareil.
