Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Inspect the wires and determine if there are enough strands that can be soldered together to make a safe, reliable connection. If you can make a good connection with the old wires, press them together so there are no strands fraying outward. If there are only a couple wires still connected and the severed ends can not reach each other, or the wire is completely severed, you will need to splice in some new wire.
  • Inspect the wires and determine if there are enough strands that can be soldered together to make a safe, reliable connection.
  • If you can make a good connection with the old wires, press them together so there are no strands fraying outward.
  • If there are only a couple wires still connected and the severed ends can not reach each other, or the wire is completely severed, you will need to splice in some new wire.
Insérez ici votre traduction
