Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
Once the screws and ribbons are removed, use the nylon spudger to gently remove the plate holding the rest of the components and set to the side. Once the plate has been removed, located the (4) 3mm T4 Torx screws and remove them. There is a single ribbon here that has to be removed as well. Follow the ribbon to where it connects. Gently lift the tab using the spudger or a fingernail. Once the tab is open, gently pull the ribbon out and away.
  • Once the screws and ribbons are removed, use the nylon spudger to gently remove the plate holding the rest of the components and set to the side.
  • Once the plate has been removed, located the (4) 3mm T4 Torx screws and remove them.
  • There is a single ribbon here that has to be removed as well. Follow the ribbon to where it connects. Gently lift the tab using the spudger or a fingernail. Once the tab is open, gently pull the ribbon out and away.
Insérez ici votre traduction
