Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 7
Étape 7
Remove two 2.7 mm Phillips #00 screws holding down the pressure plate. Use tweezers to lift back the battery connector, which is located directly under the pressure plate. Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
  • Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
  • Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
Insérez ici votre traduction
