Aller au contenu principal
Anglais
Français
Traduction de l’étape 33
Étape 33
Flip the brush cage assembly over. Arrange so the two "arms" are facing you. On one side, pull apart the green cage arm from the blue housing arm and lift out. Repeat on the other arm. The green brush cage assembly will lift out of the blue housing.
  • Flip the brush cage assembly over. Arrange so the two "arms" are facing you.
  • On one side, pull apart the green cage arm from the blue housing arm and lift out.
  • Repeat on the other arm. The green brush cage assembly will lift out of the blue housing.
Retournez l'ensemble du compartiment à brosse. Disposez ainsi les deux "bras" tournés vers vous.
D'un côté, écartez l'un des bras du compartiment verte de ceux du carter bleu et soulevez-le.
Répéter sur l'autre bras. L'ensemble du compartiment à brosse verte se soulève du boîtier bleu.
