Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
To observe the LED's you need to apply power to the iMac with the front bezel off.  Please ensure you don't touch any part of the iMac or the exposed circuit boards while you have power connected.
  • To observe the LED's you need to apply power to the iMac with the front bezel off. Please ensure you don't touch any part of the iMac or the exposed circuit boards while you have power connected.
  • Locate the Diagnostic LED's between the RAM slots and the SATA connector.
  • The LED's are numbered 1-4 from left to right. You may need to move the SATA cable to get a clear view of the LED's.
  • If you are using this guide for iMac Intel 20" EMC 2210 and 2133 the LED's are located above the SATA connector and not as visible.
  • LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
  • LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
  • LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
  • LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Pour observer les LED, vous devez mettre l'iMac sous tension avec le cache avant éteint. Veillez à ne toucher aucune partie de l'iMac ou les circuits imprimés à découvert lorsque l'iMac est sous tension.
Localisez les LED de diagnostic situées entre les fentes de RAM et le connecteur SATA.
Les voyants LED sont numérotés de 1 à 4 (de gauche à droite). Vous devrez peut-être écarter le câble SATA pour obtenir une meilleure vue des LED.
Si vous utilisez ce tutoriel pour un iMac Intel 20" EMC 2210 et 2133, les voyants sont situés au-dessus du connecteur SATA et ne sont pas visibles.
LED 1 - Indique que la carte mère principale détecte la tension du bloc d'alimentation. Ce voyant s'allume lorsque l'iMac est branché à l'adaptateur secteur, même si l'ordinateur est fermé ou en mode veille. Il s'éteint juste si l'ordinateur est débranché ou que le bloc est défectueux.
LED 2 - Indique que la carte logique principale détecte le courant du bloc d'alimentation lorsque l'ordinateur est allumé. Ce voyant s'allume lorsque l'ordinateur est allumé et que le bloc d'alimentation fonctionne correctement.
LED 3 - Indique que l'ordinateur et la carte vidéo communiquent. Ce voyant s'allume lorsque l'ordinateur communique correctement avec la carte vidéo. Si les voyants 1 et 2 sont allumés et que vous entendez le son de démarrage, mais que le voyant 3 est éteint, la carte vidéo risque d'être défectueuse et de devoir être remplacée.
LED 4 - Indique que l'ordinateur et le panneau de l'écran LCD communiquent. Ce voyant s'allume lorsque l'ordinateur est allumé et qu'un signal vidéo est généré. Si le voyant est allumé et qu'il n'y a pas d'image sur le panneau LCD, le LCD ou l'inverter peuvent être montés de façon incorrecte ou doivent être remplacés.
