Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Slide the pointed end of the spudger into the slot under the upper right corner of the ear speaker and gently pry upwards. Be careful during this step, as the upper portion of the speaker can easily detach from the lower portion, causing the coil inside to unwind. Be sure to pry the entire assembly up.
  • Slide the pointed end of the spudger into the slot under the upper right corner of the ear speaker and gently pry upwards.
  • Be careful during this step, as the upper portion of the speaker can easily detach from the lower portion, causing the coil inside to unwind. Be sure to pry the entire assembly up.
  • Lift the ear speaker up and out of the device.
Faites glisser l'extrémité pointue de la spatule dans la fente sous le coin en haut à droite du haut-parleur interne et faites délicatement levier.
Faites très attention lors de cette étape car la partie supérieure du haut-parleur interne se détache facilement de la partie inférieure, suite à quoi la bobine à l'intérieur se déroule. Assurez-vous de soulever tout ensemble.
Retirez le haut-parleur interne de l'appareil.
