Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to  the inner plastic frame. Use the plastic opening tool to carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire. Use the plastic opening tool to carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
  • Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
  • Use the plastic opening tool to carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
Insérez ici votre traduction
