Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 7
Étape 7
Gently remove the cables from their plastic support tabs. Insert a flathead screwdriver itn the hole near the L-shaped part. slightly rotate it downwards  and slide the entire bottom of the drive right until it stops. Lift the cover while being careful not to break the cables.
Optical drive lower panel
  • Gently remove the cables from their plastic support tabs.
  • Insert a flathead screwdriver itn the hole near the L-shaped part. slightly rotate it downwards and slide the entire bottom of the drive right until it stops.
  • Lift the cover while being careful not to break the cables.
Insérez ici votre traduction
