Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 9
Étape 9
If you have a stuck disc, this is the step you are looking for! Remove the three PH1 screws.
Top cover
  • If you have a stuck disc, this is the step you are looking for!
  • Remove the three PH1 screws.
  • (I forgot to take the photo...) Insert a spudger (or similar) in the gap between the two parts of the drive and slide it along the corners. Around the yellow squares there are two clips which will pop when you slide the spudger.
  • Rotate the top cover and remove any stuck disc. Be careful not to break any part on the top!
Insérez ici votre traduction
