Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
The logic board is still connected to the front case by the display ribbon cable, located on the headphone jack side of the logic board. Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected).  Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
  • The logic board is still connected to the front case by the display ribbon cable, located on the headphone jack side of the logic board.
  • Lift the logic board assembly out of the front case from the click wheel connector side (the cable you just disconnected). Rotate the logic board assembly about the display ribbon cable and lay it next to the front case.
Insérez ici votre traduction
