Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Using the edge of the cylinder removal tool, depress the tab from step 2 while removing the driver bar.
  • Using the edge of the cylinder removal tool, depress the tab from step 2 while removing the driver bar.
  • You should be able to pull the driver bar right out by hand. If it doesn't come out easily, here are a few tips:
  • Make sure the tab from step 1 is completely vertical and pointing towards one of the threaded cylinders. It can easily shift out of position, preventing removal of the driver bar.
  • Rotate the entire assembly 180 degrees so that the keyway faces the ceiling. While depressing the tab from step 2, wiggle the entire lockset. The driver bar should slide right out.
Insérez ici votre traduction
