Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 12
Étape 12
Remove the upper spring seat and pull the spring off the strut assembly. If you are installing new springs you will need to remove the spring compressors. Loosen each spring compressor evenly, alternating from side to side until they are off the spring completely.
  • Remove the upper spring seat and pull the spring off the strut assembly.
  • If you are installing new springs you will need to remove the spring compressors. Loosen each spring compressor evenly, alternating from side to side until they are off the spring completely.
  • When installing new springs you will need to compress them with the spring compressors before placing them on the strut assembly.
  • If you are reinstalling the same springs you may keep the compressors in place until it is time to reassemble the suspension.
Insérez ici votre traduction
