Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
The ball joint is held to the control arm by three 18 mm bolts. Remove the bottom two nuts with a breaker bar or long wrench. Place a breaker bar over the gold nut on the bottom of the control arm.
  • The ball joint is held to the control arm by three 18 mm bolts.
  • Remove the bottom two nuts with a breaker bar or long wrench.
  • Place a breaker bar over the gold nut on the bottom of the control arm.
  • The breaker bar alone will not be able to loosen the nut, since the bolt is free to rotate.
  • Place an 18 mm box end wrench over the bolt on top of the control arm.
  • Turn the breaker bar and the wrench in their respective counterclockwise directions to loosen and remove the third ball joint-to-control arm bolt.
Insérez ici votre traduction
