Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
Optical Drive
  • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
  • On some models, the subwoofer connector is soldered to the logic board and will break if you pry it off. If you need to replace the speaker/subwoofer, you can pull back the foam padding on the connector and remove the red and black wires to disconnect. You will need to reinsert the wires from the new speaker to reconnect.
  • If you are only removing the optical drive and not replacing the speaker/subwoofer, you do not need to disconnect this connector.
À l'aide de l'extrémité plate d'un spudger, faites levier sur le connecteur du caisson de basses pour le débrancher de la carte mère.
+[title] Optical Drive
[* black] Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
+[* icon_caution] On some models, the subwoofer connector is soldered to the logic board and will break if you pry it off. If you need to replace the speaker/subwoofer, you can pull back the foam padding on the connector and remove the red and black wires to disconnect. You will need to reinsert the wires from the new speaker to reconnect.
+[* icon_note] If you are only removing the optical drive and not replacing the speaker/subwoofer, you do not need to disconnect this connector.
