Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the set screw securing the shifter yoke pin. This assembly can be located on the underside of the car, above the transmission and directly below the shift lever. Grab the head of the shifter yoke pin with your hands or pliers and pull it out.
  • Remove the set screw securing the shifter yoke pin. This assembly can be located on the underside of the car, above the transmission and directly below the shift lever.
  • Grab the head of the shifter yoke pin with your hands or pliers and pull it out.
  • If the pin won't readily come free, try jiggling the shifter while you pull the pin.
Insérez ici votre traduction
