Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Support the drive shaft with a jack, jack stand, or other prop so it does not fall and get damaged or injure someone when the support is removed. Remove the 4 bolts securing the drive shaft support. Do not lose the washers on the 4 bolts or the spring and washer on the opposite side of the support.
  • Support the drive shaft with a jack, jack stand, or other prop so it does not fall and get damaged or injure someone when the support is removed.
  • Remove the 4 bolts securing the drive shaft support.
  • Do not lose the washers on the 4 bolts or the spring and washer on the opposite side of the support.
  • Slowly lower the drive shaft and separate it from the transmission.
  • Remove the guibo and metal separator plate.
  • The separator may not come out with drive line and will be in the transmission.
Insérez ici votre traduction
