Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Remove the bolts securing the transmission to the engine and to the starter. Support the transmission so it doesn't fall when the final support is removed. Generally, a jack is recommended for this.
  • Remove the bolts securing the transmission to the engine and to the starter.
  • Support the transmission so it doesn't fall when the final support is removed.
  • Generally, a jack is recommended for this.
  • Remove the four bolts securing the transmission support to the chassis.
  • Lower the transmission out of the car.
  • In many instances, the transmission may not come free from the engine once the bolts are removed. If this is the case, a pry bar is recommended to help separate the two.
Insérez ici votre traduction
