Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable. Use the tip of a spudger to flip the "lever" of the ZIF connector (left side in first photo) on the hard drive cable. The connector does not come off, see next instruction. Gently pull the yellow sensor bracket cable out of the ZIF connector (to the right, in the second photo).
  • Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable.
  • Use the tip of a spudger to flip the "lever" of the ZIF connector (left side in first photo) on the hard drive cable. The connector does not come off, see next instruction.
  • Gently pull the yellow sensor bracket cable out of the ZIF connector (to the right, in the second photo).
  • Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket to which it is adhered.
  • Remove the adhesive backing from your new hard drive cable, stick it onto the sensor bracket, and connect the sensor bracket cable.
  • Many fixers cover the length of the thicker cable in the pair with sections of electrical tape on both sides because it can rub the tiny ridges inside the aluminum case causing a short to the case itself or simply breaking the connection.
Votre pièce de rechange peut être livrée avec ou sans le support avant (du capteur). S'il n'y est pas, vous devrez le transférer sur le nouveau câble.
Avec la pointe d'une spatule, ouvrez le connecteur ZIF sur le câble du disque dur.
Tirez doucement le câble du support du capteur hors du connecteur ZIF.
Avec l'extrémité plate d'une spatule, déconnectez le câble du disque dur du support du capteur.
Ôtez la bande adhésive à l'arrière du nouveau câble du disque dur, collez-la sur le support du capteur et connectez le câble du support du capteur.
De nombreux réparateurs couvrent la longueur du plus épais des deux câbles avec des morceaux de ruban adhésif isolant des deux côtés, car il peut frotter les crêtes du boîtier à l'intérieur du boîtier en aluminium et donc causer un court circuit sur le boîtier lui-même ou tout simplement briser la connexion.
