Aller au contenu principal
Anglais
Français
Traduction de l’étape 5
Étape 5
Remove the plastic trunk liner screws to gain access to the wiring behind the navigation computer Slide out navigation drive and disconnect the blue and magenta plugs Once the computer is removed you will need to remove the connectors on the back of the navigation computer (please, make sure the power light is OFF before disconnecting battery or wiring to the navigation computer)  Remove the plastic frame around the navigation computer and the two plastic screws to the right of the CD changer.  Once all of these pieces are removed, you can easily lift the trunk electronics cover out of the way.
  • Remove the plastic trunk liner screws to gain access to the wiring behind the navigation computer
  • Slide out navigation drive and disconnect the blue and magenta plugs
  • Once the computer is removed you will need to remove the connectors on the back of the navigation computer (please, make sure the power light is OFF before disconnecting battery or wiring to the navigation computer) Remove the plastic frame around the navigation computer and the two plastic screws to the right of the CD changer. Once all of these pieces are removed, you can easily lift the trunk electronics cover out of the way.
  • To access the old phone equipment (Motorola TCU), you will need to remove the three 10mm bolts holding the Video module bracket in place. The only bracket typically to be removed is this bracket located to the left of the CD changer.
Insérez ici votre traduction
