Aller au contenu principal
Anglais
Français
Traduction de l’étape 8
Étape 8
The last step on the installation is to slide the center console arm rest all the way forward and gently remove the access cover for the rear of the arm rest by lifting straight up from the area closes to the rear seats. Remove the two Phillips head screws and slide the arm rest towards the front of the car.  Be careful as once you side it forward it will come completely free of the arm rest and only be held on by the wires. Once the center console is out, remove the two parcel trays inside the arm rest containers by gently lifting up from the front side first.
  • The last step on the installation is to slide the center console arm rest all the way forward and gently remove the access cover for the rear of the arm rest by lifting straight up from the area closes to the rear seats.
  • Remove the two Phillips head screws and slide the arm rest towards the front of the car. Be careful as once you side it forward it will come completely free of the arm rest and only be held on by the wires.
  • Once the center console is out, remove the two parcel trays inside the arm rest containers by gently lifting up from the front side first.
Insérez ici votre traduction
