Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen. Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
  • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
  • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
  • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
  • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
A l'aide d'un iSclack ou d'une ventouse avec poignée, séparez l'ensemble écran du panneau arrière.
Ne retirez pas encore complètement le panneau arrière. Il y a encore une nappe ! Elle relie le lecteur d'empreintes digitales à l'ensemble écran.
[* icon_caution] Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
black] Use an iSclack or a suction handle to separate the display unitphone assembly from the rear panel.
[* icon_note] In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the
panel.
panel.
[* icon_caution] Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
