Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
An additional 3.76 mm Phillips screw is hidden under the seal that reads, "WARRANTY VOID IF SEAL BROKEN OR REMOVED." Remove this sticker to access the screw. Remove the screw.
  • An additional 3.76 mm Phillips screw is hidden under the seal that reads, "WARRANTY VOID IF SEAL BROKEN OR REMOVED." Remove this sticker to access the screw.
  • Remove the screw.
Une vis cruciforme supplémentaire de 3,76 mm est dissimulée sous le sceau indiquant: "La garantie est annulée si le sceau est brisé ou enlevé." Retirez cet autocollant pour accéder à la vis.
Retirez la vis.
