Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
Now slide the metal pieces away from each other to move past the hooks and then off carefully.  As the two pieces separate be sure to carefully unplug the two wires to not cause any damage to the device. For Drobo 5D (and possibly others), you need only remove 2 screws (of the 4) on each side before sliding the back plate off. For Drobo 5D (and possibly others), you need only remove 2 screws (of the 4) on each side before sliding the back plate off.
  • Now slide the metal pieces away from each other to move past the hooks and then off carefully. As the two pieces separate be sure to carefully unplug the two wires to not cause any damage to the device.
  • For Drobo 5D (and possibly others), you need only remove 2 screws (of the 4) on each side before sliding the back plate off.
Insérez ici votre traduction
