Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
Attach the two batteries to each other with tape, in case you have two separate batteries.
  • Attach the two batteries to each other with tape, in case you have two separate batteries.
  • Use solder and a solder iron to attach the new battery to the wires.
  • The black wire should be connected with the negative pole of the two-wire side.
  • The wire should be warm enough to solder the battery to the wire.
  • Slide the tubings on each connection and heat each tubing with a lighter to make them shrink.
Insérez ici votre traduction
