Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 29
Étape 29
If you are buying a new upper case from us, the next two steps are not necessary. Your upper case will come with these parts preinstalled. Remove the following screws securing the battery connector cover to the upper case:
  • If you are buying a new upper case from us, the next two steps are not necessary. Your upper case will come with these parts preinstalled.
  • Remove the following screws securing the battery connector cover to the upper case:
  • One 2.5 mm Phillips screw.
  • Two 1.5 mm Phillips screws.
  • Lift the battery connector cover out of the upper case.
Insérez ici votre traduction
