Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the flat end of a spudger to lever the frame away from the display assembly until you can grab it with your hand. Lift near the retaining tabs marked by red rectangles in the first picture. Remove the frame from the display assembly.
  • Use the flat end of a spudger to lever the frame away from the display assembly until you can grab it with your hand.
  • Lift near the retaining tabs marked by red rectangles in the first picture.
  • Remove the frame from the display assembly.
  • While removing the frame there may be sticky residue that will generate some resistance to the detachment of the top half of the frame.
Insérez ici votre traduction
