Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 1
Étape 1
Remove the four 2.4 mm Phillips #00 screws attaching the LCD to the front glass panel. Rotate the top of the LCD 90 degrees away from the front glass panel as shown in the second picture. Rotate the LCD and front glass panel slowly so you don't damage the antenna on the bottom of the LCD.
  • Remove the four 2.4 mm Phillips #00 screws attaching the LCD to the front glass panel.
  • Rotate the top of the LCD 90 degrees away from the front glass panel as shown in the second picture.
  • Rotate the LCD and front glass panel slowly so you don't damage the antenna on the bottom of the LCD.
  • Separate the LCD and front glass panel.
Insérez ici votre traduction
