Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Pull the back cover away from the phone to remove it. The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces. The battery must remain in the phone and not come off with the back cover or you will break the power lead.
  • Pull the back cover away from the phone to remove it.
  • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
  • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
  • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
Insérez ici votre traduction
