Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 10 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use a heat gun or hair dryer to soften the adhesive underneath the camera cover. The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
  • Use a heat gun or hair dryer to soften the adhesive underneath the camera cover.
  • The following steps were performed without the use of a heat gun. Notice that the camera cover cracks very easily if you do not heat the adhesive that holds it in place.
  • Gently pry up the bottom edge of the camera cover with a plastic opening tool.
  • Carefully slide the plastic opening tool across the bottom edge to free it from the adhesive.
  • Continue to use the heat gun as needed to soften the adhesive as you remove the camera cover.
Insérez ici votre traduction
