Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 11
Étape 11
Starting at the upper right hand corner, use a spudger to gently lift the motherboard out of the casing assembly. The motherboard is still attached to the casing by a connector on the back of the motherboard. Do not pull the motherboard all the way out, or you may damage the connector. The motherboard is still attached to the casing by a connector on the back of the motherboard. Do not pull the motherboard all the way out, or you may damage the connector.
  • Starting at the upper right hand corner, use a spudger to gently lift the motherboard out of the casing assembly.
  • The motherboard is still attached to the casing by a connector on the back of the motherboard. Do not pull the motherboard all the way out, or you may damage the connector.
Insérez ici votre traduction
