Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper. Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
  • Use an open-end wrench to loosen the 11 mm fitting where the brake hose attaches to the caliper.
  • Brake fluid will come out of the loosened brake hose. You should keep a bucket or pan nearby to collect it.
  • Be careful when handling brake fluid, as it may strip paint and dissolve some plastics.
  • Detach the brake hose and remove the brake caliper.
  • When you install the new calipers you will need to bleed the brakes to remove any air from the brake fluid lines.
Insérez ici votre traduction
