Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  • Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
  • This screw is located in a gap within the right speaker assembly, and is visible only from the hinge edge.
Retirez la vis Phillips 2,2 mm insérée horizontalement à l'intérieur du lecteur optique.
[* red] Remove the single 2.2 mm Phillips screw inserted horizontally into the side of the optical drive.
+ [* icon_note] This screw is located in a gap within the right speaker assembly, and is visible only from the hinge edge.
