Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 15 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove following two screws: Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
  • Remove following two screws:
  • Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments before proceeding.
  • One 8.6 mm Phillips screw
  • One 3.9 mm Phillips screw
  • Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
Retirez les deux vis suivantes :
Soyez prudents ! La tête de ces vis est très fragile. Exercez une pression suffisante lorsque vous dévissez. Lisez les commentaires avant de procéder.
Une vis Phillips 8,6 mm.
Une vis Phillips 3,9 mm.
Avec précaution, faites pivoter la carte AirPort/Bluetooth (avec les câbles AirPort/d'antenne toujours connectés) hors du boîtier inférieur
[* black] Remove following two screws:
[* icon_caution] Take care, as these screws are unusually easy to strip. Apply firm pressure while unscrewing. Read comments on the right before proceeding.
[* red] One 8.6 mm Phillips screw
[* orange] One 3.9 mm Phillips screw
[* black] Carefully rotate the AirPort/Bluetooth board housing (with AirPort/Antenna cables still attached) out of the lower case.
