Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Unscrew ten screws using a Phillips #000 screwdriver. Push screwdriver into screw and then turn, keeping firm pressure on the screwdriver, to avoid stripping the screw. After unscrewing a screw, place it next to the hole it was taken from. When it is time to replace the screws this will avoid any confusion, as there are several longer screws.
Remove Screws
  • Unscrew ten screws using a Phillips #000 screwdriver. Push screwdriver into screw and then turn, keeping firm pressure on the screwdriver, to avoid stripping the screw.
  • After unscrewing a screw, place it next to the hole it was taken from. When it is time to replace the screws this will avoid any confusion, as there are several longer screws.
Dévissez dix vis à l'aide d'un tournevis cruciforme #000. Insérez le tournevis dans la tête de vis et conservez une pression ferme sur le tournevis, pour éviter de rayer la vis.
Après avoir dévissé une vis, posez-la près du trou duquel elle a été retirée. Quand il sera temps de remettre les vis, cela évitera toute confusion, étant donné que les vis sont plus ou moins longues.
