Aller au contenu principal
Emson Star Wars R2-D2 Humidifier LED Replacement
Anglais
Français
Traduction de l’étape 4
Étape 4
Emson Star Wars R2-D2 Humidifier LED Replacement: étape 0, image 1 de 2 Emson Star Wars R2-D2 Humidifier LED Replacement: étape 0, image 2 de 2
  • Lay the bottom part of the device upside down on a table.
  • Locate the four PH1 screw heads on the underside.
  • We used the driver and 150mm driver extension with a PH1 screwdriver bit (from 64 Bit Driver Kit) to elongate the driver. (See note below and second image)
  • NOTE: The PH1 screw heads are located 5cm into the device. Make sure to use a PH1 Driver that is at most 1cm in diameter and at least 5cm in depth.
Insérez ici votre traduction
