Aller au contenu principal
Emson Star Wars R2-D2 Humidifier LED Replacement
Anglais
Français
Traduction de l’étape 7
Étape 7
Emson Star Wars R2-D2 Humidifier LED Replacement: étape 0, image 1 de 1
  • To remove the blue LED, carefully pull the LED through the holes on the connector.
  • To add the new LED, make sure to connect the longer metal side (positive end) to the red side on the connector (positive end). The shorter end (negative side) should be connected to the black wire (negative side).
  • Once the LED is in and to make sure the LED stays connected, bend the metal ends at least 90 degrees to prevent it from sliding out of the connector.
Insérez ici votre traduction
