Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
After removing the screws and two external pieces, the PCB Logic Board can be removed from the front piece. Simply pull up on the PCB Logic Board to remove. CAUTION: Be careful of the LCD screen and keypad as they are only connected via ribbon cables to the board. They will hang down as the PCB Logic Board is removed.
  • After removing the screws and two external pieces, the PCB Logic Board can be removed from the front piece.
  • Simply pull up on the PCB Logic Board to remove.
  • CAUTION: Be careful of the LCD screen and keypad as they are only connected via ribbon cables to the board. They will hang down as the PCB Logic Board is removed.
Insérez ici votre traduction
