Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 153 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 20
Étape 20
Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer. The digitizer cable is located approximately  2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad. The digitizer cable is located approximately  2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
  • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
  • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
Faites glisser le médiator le long du bord gauche de l'iPad pour décoller l'adhésif. Tout le long du côté gauche, l'adhésif est mince à cause du numériseur. Assurez-vous que le médiateur ne rentre pas trop profond (1,2 cm max) pour éviter d'endommager le numériseur.
La nappe du numériseur est située à environ 5 cm du bas de l'iPad. Arrêtez de glisser le médiator un peu moins de 6 cm avant le bas de l'iPad.
[* black] Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
[* icon_caution] The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
