Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
Let's hope that Samsung's improved testing procedures are what the Note7 was missing, because this design looks about the same to us. And it's still a bear to pry it off that adhesive. Even with the battery fully removed, the glue won't let go. The S8+ features a 13.48 Wh (3500 mAh at 3.85 V) battery—the exact same capacity as the Note7, and a little less than the S7 Edge's 13.86 Wh.
  • Let's hope that Samsung's improved testing procedures are what the Note7 was missing, because this design looks about the same to us.
  • And it's still a bear to pry it off that adhesive. Even with the battery fully removed, the glue won't let go.
  • The S8+ features a 13.48 Wh (3500 mAh at 3.85 V) battery—the exact same capacity as the Note7, and a little less than the S7 Edge's 13.86 Wh.
  • Samsung continues to beat Apple in the battery capacity wars, with the iPhone 7+ weighing in at 11.1 Wh (2900 mAh at 3.82 V).
  • However, the iPhone may make better use of its smaller battery, outlasting the S8+ in use testing.
Espérons que les procédures de test améliorées de Samsung sont ce qui a manqué au Note 7, car ce design nous semble plutôt identique.
Et c'est toujours très dur de décoller cet adhésif. Même quand la batterie est complètement retirée, la colle résiste.
Le S8+ dispose d'une batterie de 13,48 Wh (3500 mAh à 3,85 V) – exactement la même capacité que le Note 7 et un peu moins que les 13,86 Wh du S7 Edge.
Samsung continue de battre Apple dans la guerre des capacités de batteries, l'iPhone 7+ ne disposant que de 11,1 Wh (2900 mAh à 3,82 V).
Par contre, l'iPhone fait un meilleur usage de sa batterie plus petite. Lors de tests d'utilisation, il a duré plus longtemps que le S8+.
