Aller au contenu principal
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the spudger to push in the white tab on the square circuit board attached to the front case. Use your finger to pull back the black plastic mount on the right side of the circuit board. While holding back the black plastic mount, use the tweezers to gently lift the ribbon attached to the circuit board.
  • Use the spudger to push in the white tab on the square circuit board attached to the front case.
  • Use your finger to pull back the black plastic mount on the right side of the circuit board.
  • While holding back the black plastic mount, use the tweezers to gently lift the ribbon attached to the circuit board.
  • The ribbon and circuit board should both detach from the front case.
Insérez ici votre traduction
