Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
The A/V port is glued to the motherboard. Heat should be applied carefully with a heat gun to loosen the adhesive.
  • The A/V port is glued to the motherboard. Heat should be applied carefully with a heat gun to loosen the adhesive.
  • Remove the A/V port with a spudger.
Le port av est collé à la carte mère. Appliquez soigneusement la chaleur avec un pistolet thermique pour desserrer l'adhésif.
Retirez le port avec un spudger.
-[* red] The av port is glued to the motherboard. Carefully apply heat with a heat gun to loosen the adhesive.
-[* black] Remove the port with a spudger.
+[* red] The A/V port is glued to the motherboard. Heat should be applied carefully with a heat gun to loosen the adhesive.
+[* black] Remove the A/V port with a spudger.
