Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 13
Étape 13
Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side. If it is difficult to pry out the connector completely with the spudger, you may remove it by hand. If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
  • Disconnect the camera from the motherboard. There are 1.5mm gaps on either side of the connector between the connector and its port. Put the pointed end of the spudger in one gap at a time and "walk" the connector out by wedging out the connector on each side.
  • If it is difficult to pry out the connector completely with the spudger, you may remove it by hand.
Débranchez l'appareil photo de la carte mère. Il y a des espaces de 1,5 mm de chaque côté du connecteur entre le connecteur et son port. Placer l'extrémité pointue du spudger dans un espace à la fois et "guidez" le connecteur en coinçant le connecteur de chaque côté.
S'il est difficile de dégager complètement le connecteur avec le spudger, vous pouvez l'enlever à la main.
