Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 52 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Carefully place a suction cup halfway up the heated side. Be sure the cup is completely flat on the screen to get a tight seal. While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
  • Carefully place a suction cup halfway up the heated side.
  • Be sure the cup is completely flat on the screen to get a tight seal.
  • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
  • If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and fold it into a handle.
Placez précisément une ventouse au milieu de la partie chauffée.
Assurez-vous que la ventouse est bien à plat pour avoir la meilleure traction.
En même temps que vous retenez l'iPad vers le bas, tirez progressivement sur la ventouse pour séparer le panneau vitré avant du boitier arrière.
[* black] Carefully place a suction cup halfway up the heated side.
[* black] Be sure the cup is completely flat on the screen to get a tight seal.
[* black] While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
[* icon_note] If your iPad's screen is badly cracked, covering it with a smooth layer of clear packing tape may help the suction cup adhere. Alternatively, use a strong piece of tape (such as duct tape) and [https://d3nevzfk7ii3be.cloudfront.net/igi/NgVMfmOgJwEalMFF.huge|fold it into a handle|new_window=true].
